Mit Lisy 5.28-91.pre3 funktioniert's. Das ist wohl auch die Version, die wir bei Volley benutzt haben. Bei der neuen Lisy Version scheint da also irgendwas bezüglich System 3 schief gegangen zu sein, alles andere funktioniert gut. Hier der Vollständigkeit halber der Anfang vom Log: ^Cpi@lisy(ro):~$ ./run_lisy_apc make sure getty process is stopped LISY basic DEBUG activ [830.070623][0.000009] LISY DEBUG timer set [830.070880][0.000257] Info: udp switch reader server for debug mode succesfully started [830.070929][0.000049] LISY APC Hardware init start LISY_Mini: HW Client is: APC Info: serial com successfull initiated [831.072565][1.001636] check if connected hardware is"APC" [831.073472][0.000907] connected HW is: APC Info: check ID for 'APC' returns 0 [831.074550][0.001078] LISY_Mini: Client has SW version: 01.04 [831.075509][0.000959] LISY_Mini: Client uses API Version: 0.10 [831.076107][0.000598] LISY_Mini: Client supports 65 lamps [831.076678][0.000571] LISY_Mini: Client supports 25 solenoids [831.077251][0.000573] LISY_Mini: Client supports 3 displays [831.078013][0.000762] Display no:0 has type:0 (Display index is invalid or does not exist in machine.) with 0 segments [831.078772][0.000759] Display no:1 has type:4 (SEG14,Fully addressable 14 Segment Display (with comma)) with 16 segments [831.079526][0.000754] Display no:2 has type:4 (SEG14,Fully addressable 14 Segment Display (with comma)) with 16 segments [831.080100][0.000574] LISY_Mini: Client supports 73 switches Switch Status 1..8;9..16;17..24; ...: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 advance: 0 UP/Down: 0 [831.133133][0.053033] LISY DEBUG activ for displays [831.133178][0.000045] LISY DEBUG activ for switches [831.133215][0.000037] LISY DEBUG activ for lamps [831.133252][0.000037] LISY DEBUG activ for coils [831.133288][0.000036] LISY DEBUG activ for sound [831.144348][0.011060] Info: LISYAPC Throttle value is 120 for this game LISY_APC: we are emulating Game No:4 disco_l1 info: trying to parse: /usr/local/share/xpinmame/xpinmamerc info: trying to parse: /root/.xpinmame/xpinmamerc info: trying to parse: /usr/local/share/xpinmame/xpinmame-vid_lisyrc info: trying to parse: /root/.xpinmame/xpinmame-vid_lisyrc info: trying to parse: /usr/local/share/xpinmame/rc/disco_l1rc info: trying to parse: /root/.xpinmame/rc/disco_l1rc Info: internal Hardware revision is 122 LISY80_SIG_HANDLER: SIGUSR1 catched This is LISY (Lisy W) by bontango, Version 528 91 [831.153334][0.008986] Info: LISYMINI this game has NO SS or AC Relay [831.153478][0.000144] send cmd 31 to Display 1: str: SYS3 [831.153534][0.000056] Info_boot: System_ID: SYS3 [831.153576][0.000042] send cmd 32 to Display 2: str: DISCO FEVER [831.153629][0.000053] Info_boot: gamename: DISCO FEVER [831.153671][0.000042] send cmd 33 to Display 3: str: S2 004 [831.153723][0.000052] Info_boot: S2 Setting: 4 [831.153763][0.000040] send cmd 34 to Display 4: str: 528 91 [831.153816][0.000053] Info_boot: SW Version: 528 91 -
schmil hat sich registriert
Vielen Dank euch beiden. Bez. U15 auf Audio Board: Mist, da habe ich mich auf dem CPU Board verbissen😒. Nun anbei ein Foto vom U15 auf dem Audio Board. Dort ist ein Aufkleber drauf. Bez. Flipperfinger EOS: Das habe ich selbst auf die verschiedensten Arten ausprobiert. Ich habe auch eine Videoanleitung geschaut und da wurde es zusammengebaut wie bei älteren Flippern... Nun habe ich es korrigiert (siehe Bild anbei). Der Flipperfinger funktioniert zu Beginn sehr, sehr zögerlich und schlotternd. Mit der Zeit geht es teilweise etwas besser, aber um die Rampen hochzukommen, reicht auch dann die Kraft nicht aus. Zudem, wenn ich den Flipperfinger aktivieren, Brummt es (vermutlich von der Spule). Zusatzinfo: Wenn ich im Test Menü die Flipperfinger teste, Schlägt der obere Flipperfinger mit wunderbarer Kraft wie die beiden unteren und es brummt auch nicht. Ich als Laie vermute, dass es evtl. an der zusammenhängenden Mechanik der beiden rechten Flipperfinger liegen könnte... - Früher
Das rot eingekreise ist der EOS. Der sollte normalerweise nur bei angezogenem Bumper (sicher) öffnen. Bleibt er offen funzt alles, aber die Bumper sollten schwächer sein! Und ja, du hast Recht! SO macht der Kontakt keinen Sinn! -
Das ist die CPU-Platine. Das IC U15 dort hat nichts mit der Fehlermeldung zu tun. Es geht um die Soundplatine, obere Reihe in der Mitte. Dort ist auch ein U15, das ist gemeint. Bei dem Flipperfinger muss der Blattfederkontakt (Fachbegriff EOS) justiert werden. Der EOS muss, wenn der Flipperfinger nicht aktiviert ist, offen sein, d.h., die Kontakte dürfen sich nicht berühren. Wenn der Finger dann hochgeht, muss der kleine Hebel daran dann den Kontakt schließen indem er ihn zusammendrückt. Der ist bei dir falsch herum eingebaut. Das längere Ende muss zur Spule hin und das kürzere nach aussen. Sonst funktioniert die Kraftwicklung der Spule nicht. -
So! Der Tellerkontakt funktioniert soweit wie er soll! In der Ruheposition ist der EOS Kontakt jedoch schon auf. Zieht die Bumperspule an, ist der EOS Kontakt noch weiter auf. Ich hoffe das ist auf den Fotos ersichtlich. Stutzig macht mich nur, dass der EOS Kontakt so wie er jetzt ist ja gar keinen Zweck erfüllen kann. -
Du schreibst gestern um 15:33 das 10, 100 und 1000 Punkteb richtig gezählt werden. In deiner Liste sind aber mindestend 7 Kontakte die 100 Punkte geben müssten. Was stimmt den nun? Wenn Du jemanden einen dieser Kontakte mit der Hand drücken lässt und dabei hinten in die Backbox schaust, zieht das 100 Punkte Relais an? -
Mach mal ein Foto von dem Kontakt! -
Das klingt alles schlüssig - vielen Dank für die schnelle Rückmeldung! Diese Schalter sind bei mir wie gesagt IMMER offen. Ist es sinnvoll diese so einzustellen, dass sie sich nur öffnen wenn die Bumperspulen auslösen? -
Für mich sinds 3 Stunden, passt also nicht. Wie gesagt, Firmen müsse Garantie geben. Egal ob Du eine willst oder nicht. Die werden einen alten EM also immer komplett überarbeiten (zumindest alle Fassungen, Relais, Stepper usw.), da gehen schnell ich schätze mal 30-60 Stunden ins Land. Firmenstunden mit dazu passendem Lohn. Aachen ist 'ne Stunde von Viersen? https://www.aixtraball.de/ Dann wären auch noch Herten und herne: https://www.waz.de/wochenende/article237799789/Flipper-Fans-Hier-stehen-die-Automaten-im-Ruhrgebiet-noch.html https://freeplay.ruhr/ Und Nitsche mit seinem privaten Gameroom, ich weiss nicht ob der auch Tipps geben kann. https://nitschepinball.hpage.com/index.html
