B.Zarr Geschrieben 6. Februar 2012 Geschrieben 6. Februar 2012 Hallo, bei meinem 8 Ball Champ sind auf dem Squalk and Talk sound board AS-2518-61, Roms vom Typ 2732 verbaut. Laut Schaltplan wurden 2716 oder 2532 verbaut, Was hat es mit den 2732 auf sich und wie müßten hier die Jumper eingestellt werden? Vielen Dank und liebe Grüße Helmut
Volley Geschrieben 6. Februar 2012 Geschrieben 6. Februar 2012 Biddeschön: AS-2518-61/61A/61B Squawk and Talk board: -- "A" variant added some sort of delayed-power circuit to the speech chip, presumably to correct odd noises on powerup? -- "B" variant added in/out signals for Say It Again reverb board, so only Centaur requires the B variant. (All games after Centaur shipped with B variant anyway.) If U1 CPU is a... ...then jumper this way ----------------- ----------------------------------- 6802 install K, remove L, remove U6 RAM 6808 install L, remove K, install U6 RAM -- If any of U2 through U5 are 4K (2532/9332/2732), then install jumpers C and E, and remove jumpers A and B. If only 2K chips (2716/9316) are used, then install A and B, and remove C and E. -- Original schematic has an error in the jumpering notes for 2532/9332: they neglected to list jumper "D" as needed. If U2 is a... ...then jumper this way ------------- ----------------------------------- 9316 ROM or install D and P, remove F and G 2716 EPROM 9332 ROM or install D and G, remove F and P 2532 EPROM 2732 EPROM install F and P, remove D and G If U3 is a... ...then jumper this way ------------- ----------------------------------- 9316 ROM or install Q and T, remove R and S 2716 EPROM 9332 ROM or install Q and S, remove R and T 2532 EPROM 2732 EPROM install R and T, remove Q and S If U4 is a... ...then jumper this way ------------- ----------------------------------- 9316 ROM or install U and X, remove V and W 2716 EPROM 9332 ROM or install U and W, remove V and X 2532 EPROM 2732 EPROM install V and X, remove U and W If U5 is a... ...then jumper this way ------------- ----------------------------------- 9316 ROM or install Y and BB, remove Z and AA 2716 EPROM 9332 ROM or install Y and AA, remove Z and BB 2532 EPROM 2732 EPROM install Z and BB, remove Y and AA If speech is... ...then jumper this way --------------- ----------------------------------- Required install J and remove H Not required install H and remove J If U12 is... ...then jumper this way ------------ ----------------------------------- Present remove EE jumpers (5 of them) Not present install EE jumpers (5 of them) If game is... ...then jumper this way ------------- ----------------------------------- Centaur remove FF (requires AS-2518-61B) Not Centaur install FF (if using AS-2518-61B) If volume is... ...then jumper this way --------------- ----------------------------------- CPU controlled install M and CC, remove N and DD (this is normal) Remotely controlled install N and DD, remove M and CC
B.Zarr Geschrieben 6. Februar 2012 Autor Geschrieben 6. Februar 2012 Hi Frank, das ist es genau, was ich bauche. Vielen Dank Helmut
